unlocking source distribution
So, i'm having a bunch of configuration files that are stored in a different location than the application, so i've created 2 builds, one for the .exe and one source distribution for the configuration files. The Installer works well this way and copies stuff to their respective filders in a orderly manner. So far, so good.
The problem: The ini-files get administrator rights and i cant unlock them in the installer UI. Users need to be able to modify the files. Ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,083 Views)
Accepted by topic author Yamaeda
Alright, i've created a solution, but i'm not quite happy about it, i feel there must be a leaner way about it.
I've created a vi which runs a system exec with an attrib-command. This is compiled to an exe in a separate build-definition. It's installed in the same location as the main ui and in the Installer it's set as Run after installtion.
Is this really the best way?
Why cant i simply run a system command as part of the installation but only compiled vi's? Why must i install the exe, why not a "run only with installation"?
/Y
Qestit Systems
(3,061 Views)
Hi Yamaeda,
I didn't test it, but can't you run a batch file (aka ".bat") instead of your own compiled exe (which basically does the same)?
(3,058 Views)
It doesn't seem so, in the Installer properties i can only set "Run executable at end of installation" and when browsing i can only ... *checking* ...
If i create a batch-file and add it to the .exe-build (always included) i can access it in the Run exe-options. It's a bit better, but still not 100% lean and smooth. I'd want to unlock it with the build in functions, which i think should be quite possible. I mean it's not like this is the first time the problem appears during 25 years of LV, right?
/Y
Qestit Systems
(3,055 Views)
