unresolved external symbol _wWinMain@16
I have a project that I have the ned to create a conde node and I tried to work thourgh the example avgv.c in the labview CIN directory but I can not link the code because of the following error:
LIBCD.lib(wwincrt0.obj) : error LNK2001: unresolved external symbol _wWinMain@16
I believe tihs is just a MSVC setup problem but I can not find the correct setting.
Michael
(4,381 Views)
hi there
LIBCD.LIB is a library of MSVC. it should be found at ..\VC98\lib. make sure the file exists, otherwise check the settings of your CIN project.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,374 Views)
hi,
I am also getting the same problem. If you please dont mind, please suggest me, how to resolve this. One suggestion I got from internet, did not solve my problem.
thanks
Fazal
(3,255 Views)
