unsigned bytes
Hello All,
i have a 3 different strings of Ascii  which i want to convert into Hex with a Checksum,
however i think i have gone wrong somewhere,
if i have one of my strings as a U8 and the others as U16 and U32 my byte array will not add the elements together, unless i
make all of them them a U32 (which i dont want) as i will have extra 0s padding my string, when i put them together
can someone help me with this please.
Thanks in advance
Thomas
Message 1 of 12
(6,934 Views)
Hi Thomas,
you really should attach an example of your "strings having them as U8/U16/U32". No idea what you're talking about...
Message 2 of 12
(6,933 Views)
Post your VI friend (2011) with your required input.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 12
(6,929 Views)
on the front panel i have Addr Data and command Data needs to be of a variable length however read/write only needs to be a Unsigned 8 i dont want any zeros in the concatnated string but when if i do this i can bnot add the elements in the array for the checksum
Message 4 of 12
(6,924 Views)
also i know there are  alot of things that dont need to be there they are only there for my purposes only and will be remove one i have it working!!
Message 5 of 12
(6,920 Views)
Hi Thomas,
can you also give some typical data?
It doesn't seem to be useful to typecast some strings to convert them back to strings to again convert them to an array of numbers to decimate that array. Seems not useful at all...
So we need:
- typical data for "addr", "status" and "Data"
- result needed for those data
- formula for your checksum calculation
Message 6 of 12
(6,918 Views)
addr ="xxxx"
data= is variable length
status= 4 Ascii caracters
read/write=r or w
checksum= sum of all above in hex or with 80hex
Message 7 of 12
(6,910 Views)
checksum= sum of all above ORed with 80hex
Message 8 of 12
(6,909 Views)
Accepted by topic author thomasd6
Hi Thomas,
you have been asked to provide some real data and the needed output, but have failed to...
Just a rough sketch:
Message 9 of 12
(6,900 Views)
thanks GerdW  one quick question i see that you ff anded with the result could you explain that to me please,
it works like a dream!! i didnt even know that i had a add array element function
Message 10 of 12
(6,893 Views)
