unsupported cDAQ module
I've been using a NI cDAQ-9172 with several operational modules.  I installed a new NI 9213 TC module (the only one in the crate), and MAX is saying the module is unsupported.  If I switch to a different slot in the crate, the problem moves witht the 9213 module.  I'm running 8.6.1 and have not had any problems with drivers for other 9000 series I/O modules.  Any suggestions?
Greg
Greg R.
(3,502 Views)
Check your DAQmx version in MAX.  It must be 8.8 or greater in order to use the 9213 in a cDAQ chassis.
(3,484 Views)
Well, it looks like LV 8.6.1 ships with DAQmx 8.8.  So that should have worked.  I loaded DAQmx 9.0 and rebooted, and now all my modules are recognized.  So either the reboot did it or 9.0.
Thanks much!
Greg R.
(3,479 Views)
