untraceable subVI
Hej,
an error occurred concerning "SetValueRange.vi". But I can't find this subVI, even not on my whole hard drive.
The www gives only one search result for the title of the subVI LabVIEW.
http://forums.ni.com/t5/DIAdem/Der-Import-der-GPI-Dateifilter-in-die-Dateifilterverwaltung-ist/m-p/5...
But this is unfortunately not the answer to my question.
DIAdem is also involved during my program runs an the error occurres.
Does anybody know this subVI or has an idea what to do?
Thanks!!!
Message 1 of 8
(3,989 Views)
Show your VI hierarchy and have it show full path (an option in the menu bar). That will tell you where it is located.
Tim
GHSP
Message 2 of 8
(3,964 Views)
Already done. No success!
But the VI is even not in the VI hierarchy.
I only know about this VI because of the error message.
Message 3 of 8
(3,957 Views)
Hello Konrad,
a second idea might be to take a look at the LabVIEW project dependencies. Does it show up here?
Best regards
Marian Vorderer
Message 4 of 8
(3,922 Views)
Konrad,
What kind of an error occurred?  What was the error code?  What were you doing when the error occurs?  Is this when loading a project or a program or while something is running?  What version of LV and OS?  What toolkits do you have installed?
Sometimes error messages can be misleading.  Perhaps the additional information may give someone a clue.
Lynn
Message 5 of 8
(3,914 Views)
Hello Marian,
where can I find these dependencies?
Message 6 of 8
(3,911 Views)
Hej Lynn,
I forgot to make a screen shot of the error window...worse luck! Thus I don't know the code, but I think it was undefined.
The error occurs during recording a line camera signal and writing it to an 2D array. Afterwards the array is written to TIFF and some other data analysis is done by the help of miscellaneous subVIs. DIAdem is also involved (report generation) - perhaps the error occurs there because of invalid data in the array.
After pressing continue the program hung up.
I've got Full development system 8.2 and Win XP SP2.
Message 7 of 8
(3,896 Views)
Did this work in the past on the same computer?
Who wrote the program?
Is it possible that you are missing a toolkit or module?
Message 8 of 8
(3,889 Views)
