beemerbiker wrote:
> Thanks. Hopefully, the attached vi should be in v7.0. When I select
> all and try to move with keyboard arrow keys into vacant top left
> space on front panel, the scrollers back off so that when you finish
> the move everything seems to be at top left, but, because the
> scrollers have backed off, it has in fact recreated all the empty
> space you tried to get rid of! This scroller-shift effect is as
> reported previously in this forum by another user.
Ohh, man I see what you mean and I have to say it just doesn't seem to
me like a problem. Forget the scrollbars!
LabVIEW always maintains some empty space around the controls to give
you the possibility to scroll the panel around when you want to add a
control at the border. If it wouldn't do that and you happen to have a
window which neatly contains all controls in the visible area you
couldn't scroll to the side to make more space to add some new control.
You would have to place the control on the visible panel, select it and
move it with the cursor to the non visible part before the scrollbar
would indicate there is something to unhide.
In a real application you basically always hide the scrollbars as you
don't want a user to scroll around on your panel. If you do want to let
them scroll around because you happen to have designed a panel with to
many controls to fit on the screen you have some other more important
problems to solve about your application before worrying about some
empty space (ahem you probably won't have any empty space then, would
you
🙂Basically the way I work in LabVIEW is that I place the controls as I
wish them and then resize the screen to neatly contain all the controls
This will leave you with scrollbars right and on the bottom which
indicate that there is some space left on all four sides. Don't worry
just go into File->VI Properties and there to the Window Appearence and
then check Custom and hit the Customize key to disable the scrollbars.
When the VI runs, the scrollbars will be entirely gone and you panel
looks like a professional application.
Rolf
Rolf Kalbermatter
My Blog
