unzooming with the graph palette
In my application, i'm using an intensity graph in order to display fixed size images. I programmatically set the maximum/minimum value of each axes (15547 for the X-axis and 23700 for the Y-axis) and also disabled the autosize.
Sometimes, I have to zoom on the image displayed and then go back to the original image size. To do that, i'm using the graph palette's tools.
However, when I unzoom the axis scale changes (16000 for the X-axis and 24000 for the Y-axis) and lets appear black amrgins in the plot area.
How can I avoid this ?
Thank you!
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,475 Views)
Try to uncheck the Loose Fit property of the scales. --> right click on the scale >> Loose Fit
(2,469 Views)
