up down pulse counter mydaq
Hi
I am inexperienced with labview and I need help.
One of the elements of my project has a ring magnet with many magnet poles. I rotate this manually and produce a digital input to my Mydaq (Hall Signal from Hall sensor).
The counter (which can only count up on the Mydaq) counts the pulses and I multiply the output by 9 to read the angle of rotation.
My project requires me to rotate the ring magnet forward and back.
How can I reduce the output angle when rotating backwards? i.e. create an up down counter.
With my limited knowledge, I tried using case structures and also shift registers, however I am unable to overcome the fact that the counter continues to count up when I change direction of rotation.
I have a trigger within my project to indicate change of direction
Please help......
Greg
(3,423 Views)
The counter has to know which direction the thing is turning. If there is not only one sensor it can't. You need something like a quadrature encoder to get both position and direction.
http://www.ni.com/white-paper/4763/en/
Mike .
Certified LabVIEW Architect
LabVIEW Champion
(3,390 Views)
Hi Mike
I can use a second input from a second hall sonsor so I will attempt the system in the white paper.
Many Thanks
Regards
Greg
(3,378 Views)
Mike/All
I am still stuck!
I am unable to determine the leading signal from the lagging signal.
Is it possible without the use of a counter? I only have one counter and it will only count up.
I have attached a file showing the input option that I have available to me
Help appreciated....
Thanks all
Greg
(3,359 Views)
All
Is it possible to count input pulses without a counter function?
If I can do this, I can achieve all I need to achieve.
I would need to be able to count up and down
Please advise if this is possible
Regards
Greg
(3,319 Views)
All
Got it sorted, I now am able to count up and down on two pulse signals....happy days!
Regards
Greg
(3,305 Views)
