11-21-2006 06:22 AM
11-21-2006 07:44 AM
11-21-2006 07:52 AM - edited 11-21-2006 07:52 AM
I don't have enough experience when working with the frequency domain but here is my attempt by following my nose.
There seems to be an error in the frequency detected but I don't know why. Hopefully somebody else with more knowledge will step in with an explaination.
Here it is in LV7.1
David
Edit: Ah there you perhaps gwd can help ![]()
Message Edited by David Crawford on 11-21-2006 01:53 PM
11-21-2006 07:55 AM
Hi Michael
I use cursors to do a similar task. Have a look at the example.
Hope this helps
Ian
11-21-2006 08:18 AM
Thanks guys, I'll take a look at all the examples given and see if I can figure it out. I was playing around with an event structure and based upon the event change in the waveform chart would cause the FFT to change. Hopefully by seeing the examples given I can fully implement it.
