update a command in a cluster
How can I update a command inside a cluster.
I can just read them using disassemble by name. How can I write into one of the command?
thanks in advance.
F
(3,789 Views)
feriel0209 wrote:  I can just read them using disassemble by name.
I think the function you mean here is Unbundle By Name.  Conversely, use Bundle By Name up update an item in a cluster.
(3,779 Views)
Your description is pretty vague - can you show us your code?
Are you trying to update the value in a cluster? If so, use the 'bundle by name' function. That's pretty basic...
(blog)
(3,777 Views)
Accepted by topic author feriel0209
something like this ?  [edit] (Create Property Node / Value) [/edit]
(3,765 Views)
