update cluster when typing numeric
Dear All,
I have a cluster with Numeric Control and String Control. How can I update value of Numeric Control when typing.
Please refer attach file (using LV2015)
(4,496 Views)
Hi sukichan,
a numeric control updates when you use the ENTER (or Return) key or when you click with the mouse outside of the control.
When you want to update while typing you should use a string control (set to "update while typing") or an event structure detecting key press events in your numeric control!
Can you downconvert your VI to LV2014?
(4,483 Views)
Accepted by crossrulz
Hi sukichan,
check out the code attached.
(4,473 Views)
pep91, thanks for your help.
GerdW, this is vi i convert to Labview 2014
(4,438 Views)
So, did my code solve your problems?
Kind regards.
(4,408 Views)
Hi pep91, have a nice day!
Your code can slove my problems.
(4,380 Views)
Then you should mark pep91 post as the accepted solution, not your own post thanking him.
Ben64
(4,366 Views)
