update custer elements in effecient way
        I have a cluster of 20 numeric elements. The problem, User clicks element 1 and updates the value, element 1 runs continously. Now user wants to update element 2 but element 1 does not stop and also element 2 has to run continously like element 1. Thiis follows wrt all 20 elements. How do i do in effecient way? If any examples pls do post.
Message 1 of 17
(4,301 Views)
Please post the code that you have made. The efficient way depends on how you have implemented your code and what is the change required to meet your requirement.
Message 2 of 17
(4,298 Views)
Please post VI (LabVIEW 2010), your requirements are not clear.
With Regards
Miraz
Kudos is better option to thank somebody on this forumSmiley Wink
With Regards
Miraz
Message 3 of 17
(4,292 Views)
        Thank you for your reply. I have not created any vi yet. I needed to know how its possible to make?
Message 4 of 17
(4,284 Views)
Hi Jay,
yes, that's possible.
Now please post your code!
Message 5 of 17
(4,278 Views)
Message 6 of 17
(4,272 Views)
As I said before, your problem is not clear to me, I have created something stupid here, just check whether it helps.
the only thing I made is, your cluster will always be updated with latest values set by user.
but when you say elements are going to run contineously, i thk thats not possible because user will be able to update 1 element at a time.
With Regards
Miraz
Message 7 of 17
(4,263 Views)
What is running?  That is the part none of us are understanding.  You can update a value, but there is nothing to run on a value.  So this implies that you are starting or stopping a process.  Please tell us EXACTLY what you are trying to do with your program.
Message 8 of 17
(4,235 Views)
Yes. If you have not created VI then create one. I think it's not big issue but no one able to understand without code representation.
so please if you want solution to your problem try to explain with help of code.
Thanks Jaysha
Message 9 of 17
(4,222 Views)
       For now a random number is connected. To be more precise, imagine u have 20 while loops for 20 elements and user uses those while loops accordingly depending on the element which he wants to use. The problem is that creating 20 while loops is not a good solution, so i need a effecient and better solution. The choosing of cluster elements is random.
Message 10 of 17
(4,221 Views)
