update drivers from LabVIEW 9.5 to LabVIEW 14
Hi
I am getting crazy: i had a complete control system running properly in LabVIEW 8.5 and after updating it to LabVIEW 14, nothing works.
LabVIEW is not able find the drivers of the instruments integrated in a National Instruments PXI. I am using regular drivers as NiDCpower, NiSope, etc and common functions as niDCPower Close.vi or NiScope Close.vi
After installing LabVIEW 14, I have installed the packages referenced at http://www.ni.com/download/ni-device-drivers-february-2014/4634/en/
but my application is not able to find the drivers.... What can I do?
Message 1 of 11
(3,847 Views)
The last version of DAQmx to support LabVIEW 8.5 was DAQmx 9.3 (DAQmx and LabVIEW Version Compatibility).  The latest drivers do not support LabVIEW 8.5.  I recommend using another computer to maintain your code in 8.5, use a Virtual Machine, or update your program to LabVIEW 2014.
Message 2 of 11
(3,835 Views)
LabVIEW is released in August, so the drivers appropriate for LabVIEW 2014 would be the August 2014 release.  There is also the 2014 SP1 release in February 2015, but if you installed LabVIEW 2014 (not SP1), you might start with the August 2014 drivers.  Note you can always install a more recent set of LabVIEW software, but you can't install an older set without "starting over" (i.e. removing all previous LabVIEW installations, a process that can take hours).
Bob Schor
Message 3 of 11
(3,833 Views)
Sorry but I am lost
So, If I install LabVIEW 14, what are the driver package that I have to install?
 1) the ones that appears at: http://www.ni.com/download/ni-device-drivers-february-2014/4634/en/
 2) the ones at http://www.ni.com/download/ni-daqmx-14.0/4918/en/
As I posted, what I want is to recover the control of the instruments deployed in a NI-PXI. I used common vi as NiScope Open, Close, etc
Other question, Have I to remove from this PC the previous installed version of LabVIEW?
Message 4 of 11
(3,783 Views)
Download the entire 2015 driver set from http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:4.9547.9548,ssnav:...
Or download the individual drivers. Your link to DAQmx 14 is not the latest and you would still need NiScope etc. You were already told that the February 2014 world not have support for LabVIEW 2014'
Message 5 of 11
(3,776 Views)
in summary, basically what I need are the vi functions that appears in the attached figure.
I also attach the software that I have already installed in the computer... What I need? Why this functions do not appear at LabVIEW 14? Due to the version of Ni-DAQmx (it seems that the version is 9.8 and it is not compatible with LV14)?
Message 6 of 11
(3,773 Views)
Did you post without reading what I said?
Message 7 of 11
(3,764 Views)
I think we post at the same time
Message 8 of 11
(3,749 Views)
HI
when I run the DCD-Feb15-3.exe file, the message that appears is "now extracting the February 2015 Device Driver 2 of 3 Distribution".
Previously I have installed partitions 1 and 2, I don't know why it is installing again distribution 2.
At the end of the set up, it breaks with the attached message
Message 9 of 11
(3,722 Views)
I had several complaints about the new distribution methods for these drivers, one of which is the incorrect message displayed when extracting.
http://forums.ni.com/t5/LabVIEW/New-Device-Drivers-Download-Format/td-p/3139217
Message 10 of 11
(3,695 Views)
