update global variable on front panel of another VI
I have a main VI that has the GUI for the operators that has several steps with multiple sub vi's. I want to display the status (where I am in the process) on the GUI. I am using global variables, and the status updates in the global variable front panel just fine, however it only outputs the last value to the operator GUI. I would like it to show the new status at each point in the code. I read something about action engines but I am not sure is that is the correct way. I attached some code just as an example of how I am doing it right now.
(2,798 Views)
i would implement a state machine, in your case. and look into references to bring the info up to the main vi if need to....
Spoiler
(2,793 Views)
Based on your example, a state machine would work well.  I don't like using References to update indicator values.  It causes thread swapping and is slow.  I much prefer to use User Events to send data to an Event Structure.  The event structure can then update the indicators based on the data in the event itself.
(2,759 Views)
