update txt file
You should read the data from your file... and you have a 2D array.
From that array you can compare which column or row matches your serial data.
I think you should take a look at the examples seeped with Labview..
(I did not undertand what you described)
Message 11 of 16
(952 Views)
I want to read this:
0000 joao
0001 pedro
0003 alberto, etc.
then i go to the array and if the value of the first position matches the file txt, the name appears.
i don't want the matrix's solution, or else i have to put there 100 values; i have on the  txt file.
but i don´t know if i can do this beause i only can know how to read from a txt file, lik in the examples.
thank you
Message 12 of 16
(943 Views)
i don't know if it is clear..
if it isn't please tell me and i will rephrase..
thank you very much for all help
Message 13 of 16
(939 Views)
can someone help me here?
i can't do the search because it allways apperas the first line of the file..
Can somoeno help me here and tell what i should do?
thanks
Message 14 of 16
(932 Views)
Try this...
Message 15 of 16
(918 Views)
thank you very much!
it worked!
thanks
Message 16 of 16
(904 Views)
