updating a vi while open
I want to have a main vi call a second vi.  The second vi has 2 tabs, first tab to transmit data & the second to receive data.  I want the receive data to be updating the entire time the second vi is open.  How can I do this?
(2,829 Views)
Can you transmite data while receive data?
Are you using VISA, TCP/IP, or what?
Do you need to make this only when the second vi is called, right?
(2,811 Views)
Hi Jim,
It sounds like you want to update the top level VI while the subVI is executing, and both of these are on the same machine. You can accomplish this with control references and property nodes.
This material is also covered in our LabVIEW Basics II class.
Hope that helps,
Sam
-Sam F, DAQ Marketing Manager
(2,790 Views)
