updating drivers for 8.5
I just upgraded from 8.2 to 8.5...and then installed the drivers. but when I load my program in 8.5, my program can not find the DAQmx VI's and NI SWITCH VI's in 8.5. Could anyone please tell me why this might be?
When I load the program in 8.2, all the drivers are loaded without any issues. This is so frustrating. Kindly help
PR
(2,675 Views)
Hi PR,
Thank you for contacting National Instruments.
When installing LabVIEW 8.5, make sure you are installing DAQmx version 8.6.  Previous versions of DAQmx are not compatible with LabVIEW 8.5.  In addition, make sure that you enable support for LabVIEW 8.5 during the installation as shown in the image.
If you have already installed the latest driver version, you can modify your installation and add support for LabVIEW 8.5.
After installing DAQmx 8.5, install NI-SWITCH version 3.6.  The following link will take you to the Drivers and Updates page:
http://joule.ni.com/nidu/cds/fn/p/lang/en
Keep me posted on your progress.
Hani R,
Applications Engineering
Message Edited by hanir on 09-28-2007 02:49 PM
Best Regards
Hani R.
(2,646 Views)
