upgrade application
Two years ago I created a labview application and have several hundred users.
Now I would like to distribute version 2 of the application.  I would like to have the installation procedure do the following (with as little user effort as possible):
1.  search to see if version 1 is installed.  If not, simply install version 2 as a new install.
2.  if version 1 is installed, copy all data files created with version 1 to a safe place.
3.  install version 2.
4.  take the saved data files and move them to directories to be used by version 2.
5.  uninstall version 1.
I am looking for some guidance from people who have been through this.  I can think of a number of approaches:
1.  write a labview vi which does all of the above.  I think it is possible but it may be a lot of work.
2.  figure out a way to make the labview installer generator do the above.  Don't know if this is possible.
3.  Use a windows scripting language like VB script or Perl.  Unfortunately, there is a significant learning curve here.
4.  Some combination of the above or a completely different approach.
Any help will be sincerely appreciated.
David
Message 1 of 1
(2,526 Views)
