upgrading cRIO from Labview 7 to Labview 8
Hi again 🙂
I have a cRIO system that is running Labview 7. It runs fine. No problems. We've upgraded to LV8 and I'm wondering if I should convert the LV7 system to LV8. The only reason I would do this is because for me LV8 is much easier to work with regarding cRIO (using DMA, setting up the project etc.).
Now, if I attempt to upgrade the LV7 cRIO system, what kinds of problems will I run in to?
I assume it means formatting the cRIO, installing LV8, converting the program from LV7 to LV8...
Is there an FAQ regarding this, specifically about the cRIO?
Jeff
(3,484 Views)
Hi Jeff,
Ideally you shouldn't run into any problems upgrading your cRIO system and its application to LV 8, but there is always the possibility that something may not migrate smoothly. Depending on the complexity of your application is how many different things you would have to go through.
For upgrading the cRIO controller, you should just need to upgrade software in MAX and that's it. You really don't need to reformat the cRIO, but since the operation takes only a few seconds, you can do so for your peace of mind.
For your progam, you can use the following tool that ships with LV FPGA 8.x that migrates FPGA programs written in LV 7.1 to the new LV 8.x project. You can find help about that tool in the LV Help if you just search for "Import FPGA Files" in the Index tab. You can also access the help by launching the tool and clicking its help button: Tools>>FPGA Module>>Import FPGA Files from LV FPGA Module 1.x
I suggest you migrate your program first and upgrade the controller at last. That way your LV 7 app will continue working and you wouldn't have to reinstall LV 7 on the controller if something went wrong with the migration. Be aware you will have to recompile your FPGA VI(s) and create a LV 8.x RT startup application if you are using one.
Hope this helps.  BTW, if you are using LV 8.0, I'd suggest you consider using LV 8.2 since it has several improvements over 8.0, some new features and is faster.
JMota
National Instruments R&D
(3,478 Views)
Be careful and make a complete backup of your system.
Then be sure to install all of lv8.2 including the fpga tools.  I'm not sure they are already distributed but they should be availbel in september anyway
greetings from the Netherlands
(3,469 Views)
I think our latest CD is LV8.01 or something like this. Since we have the subscription, I usually wait until I receive the CDs.
(3,440 Views)
