urgent help to save a waveform as jpeg to a specifi folder on my pc
Hello I'm practically very new to labview and maybe even to the forum that I might be posting this question in the wrong place (sorry about that). I need urgent help on the following issue (prob. a very easey one:)) here is a picture copy of one portion of my vi: I'm able to save the data in text format, no problem there. it saves the dat file into C/NLdat folder. this is ok. I also want to save the waveform chart into same folder NLdat. I did the right click on "waveform > create invoke node> get image" but doing this is not saving my jpeg anywhere. could you please show me step by step how to save it (what type of things I need to use specifically, as I feel like a idiot now) Thank you so much!
(2,406 Views)
You need to wire a Path into your Write To JPEG.
Eventually you'll want to learn how to code without using sequence structures and by using error clusters to enforce execution order.
(2,394 Views)
You also need to make sure that getting the image happens after the xy-graph has been updated. Currently both things happen in parallel and there is no guarantee what happens first. there is a 50% chance that the image contains stale data.
(2,384 Views)
