urgent - path planning
greetings fellow programmers,
I am working on DANI robot, and created a MAP of a room, by controlling the robot's movements using Labview. I have used maxsonar EZ1 sensor. Now if I have to move it from a point A to point B in the map, how would I do so?
NOTE:Assuming there are moving obstacles (or slight change in the environment), I will use the same sensor for obstacle avaidance as well.
Any information will be appreciated.
Danish
(3,743 Views)
Please do not create multiple posts. You are already being helped in your original thread: http://forums.ni.com/t5/LabVIEW/Maapping-using-Maxsonar/td-p/1997827. Keep all discussion in ONE place.
(3,722 Views)
Link doesn't work, (you have a . at the end) http://forums.ni.com/t5/LabVIEW/Maapping-using-Maxsonar/td-p/1997827 does though
(3,690 Views)
Thanks. I hate this forum software.
(3,681 Views)
oh am sorry, the topic was different, so i though of addressing it seperately. But thank you for being kind enough to inform.
Cheers
(3,673 Views)
