usage of DAQ USB-6211 with Sound and Vibration Measurement Suite
Could I use DAQ USB-6211 with Sound and Vibration Measurement Suite ? All examples are based on 24-bit devices (usually with IEPE-on) such as NI 9234 or similar.
I don't need IEPE, 16 bit is sufficient for my dynamic range, could leave without simultaneous sampling - so 6211 (that I have) is OK for me.
Actually I'm interested in S&V Toolkit ( or Measurement Suite) as a tool with some specific Signal processing capabilities (for example, short-time FFT etc.)
Thanks in advance
(2,490 Views)
Hi sgabr,
Yes, you can use the 6211 with some of the Sound and Vibration VIs, including most of the FFT functions.  I know that's a little vague -- I don't have a list of which functions do or do not support 16-bit devices, but I did test it out on my system this afternoon.  If there are specific functions or examples you'd like to know about, let me know, and I will try them out.
You also have the option to download the evaluation version of the Sound and Vibration Measurement Suite.  That way, you can test drive it yourself!
(2,456 Views)
