usb 6002
Goodnight. I would like to give me help, I have a daq 6002 and I want to work with labview 2009 I would like to know if it is possible or there is some kind of compatibility between the labview version and the driver version.
(3,371 Views)
Support for the USB 6002 started with DAQmx 9.9, and DAQmx 9.9 only supports LabVIEW 2010 to 2013.
You're probably out of luck without being able to update your version.
(3,356 Views)
I have a similar issue with the same device.
Is there a device / DAQmx compatibility table somewhere?
(3,256 Views)
(3,253 Views)
