usb-6008 limit switches analog I/O
ya the limit switches are closed by the table, but the analog input you said was open, how would i close it?
Message 11 of 19
(1,534 Views)
Open - meaning open circuit. Your design has no voltage connected to the analog input when the switch is open. With my suggestion, the analog input always has a voltage present. An open circuit on an analog input is bad because the voltage read by the DAQ card will be undefined. Do a search for 'ghosting' to see the problems associated with leaving an analog input unconnected. Avoid all of those problems by using the pullup.
Message 12 of 19
(1,532 Views)
could you please supply a sehematic of where the  pullup resistorwould be placed in relation to the rest of the circuit, or could i just use the +5V from the digital side??
Message 13 of 19
(1,528 Views)
The 6008 has a dedicated +5 output on pin 31. Use that, an analog output, a digital output, an external source, etc. The +5 output can source 200ma. Since I = V/R, use pullup values that do not exceed the max (i.e. 1K). The analog and digital outputs can source much less current so pin 31 would work best.
Message 14 of 19
(1,523 Views)
thanks! so just put a 1k resistor on the wire from pin 31, then put that to the switch, and then from the switch the AIo+ (pin 2)... ??
Message 15 of 19
(1,519 Views)
Yes, and ground the other side of the switch.
Message 16 of 19
(1,516 Views)
chers dennis... very helpful!! thanks:manhappy:
Message 17 of 19
(1,502 Views)
do i have to ground the common of the switch is it???
Message 18 of 19
(1,501 Views)
You have to wire the switch just like in the schematic.
Message 19 of 19
(1,488 Views)
