usb-6008
Hello
 I'm testing the VI example (HELP>Find Examples) "voltage - Continuous Input.vi" with the USB6008, I was able to add the other 7 AI channels to the VI, now I would like to add the digital signals also and a counter to the graph and the file being created.  Any place where could I find how to do this.
Thanks.
(2,811 Views)
Hello javilez,
In order to add the digital signals and the counter to the data that you are acquiring, you will need to create additional DAQmx Channels. If you would like to see an example of multiple data types, here is an example that uses Analog input, and Digital input and the data is synchronized using the analog input sample clock:
Help>>Find Examples>>Hardware Input and Output>>Synchronization>>Multi-Function>>Multi-Function-Synch AI-Read Dig Chan.vi
Joel
(2,771 Views)
