usb 6211 and LabView - good for IV characteristic aquisition?
Hi there,
I pre-emptively declare my lowest level in using LabView and all the annex tools, so my question won't result too silly.
I need to automatically acquire the IV characteristics for 4 solar devices, so I am thinking about connecting them to the USB 6211 in order to switch from one device to another one.
My question is: can I use a LabView Program in order to simulate the Voltage signal to apply (range c.ca -1 to +1 V), and then collect the relative current?
If so, how??
Many thanks in advance for any sort of help.
Laura
(2,735 Views)
http://zone.ni.com/devzone/cda/epd/p/id/5918
http://zone.ni.com/devzone/cda/tut/p/id/7229
LabVIEW has a toolkit available for this.  It uses an SMU card but you could simulate that with your 6211 and a current sensing resistor.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,725 Views)
There are no silly questions.
There are just silly moods to feel that so Smiley Happy
(2,707 Views)
Thank you so much for your infos!
(2,700 Views)
You are right,but you know.. sometimes the doubt is still there..!! Thanks
(2,699 Views)
