usb-6501 no supported devices found
Dennis, I read you wrote something about dig in/out for some other member.
Can I input my voltages ranging from 3 to 5v and make the usb-6501 see them as logic 1?
The problem is that no matter what input i use, they all read 4.7v, so when I run the Create Task, acquire signal, digital input, I am reading high on all pins.
How can I make it stop providing a logic high, and correctly read my high/lows that i input externally?
Thank you for any support.
Message 11 of 12
(478 Views)
A signal between 3 and 5 volts is a logic 1. If you ground an input, don't you see it as a logic 0?
Message 12 of 12
(472 Views)
