usb-9162 and 9211 application using vb.net
How can I implement ni usb-9162 and ni 9211 application using vb.net?
Do you have any vb.net library (.DLL), so that my vb.net application can read the
temperature from ni 9211? Thanks
(2,796 Views)
Hi iaaslb,
I'd like to direct you to some of our shipping examples, .net reference help, and also some great online tutorials to get you in the right direction. First off, navigate to C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0 and you'll find many examples and there are even some about temperature measurements. Also, under your start menu, go to Program Files/National Instruments/NI-DAQ/NI-DAQmx .NET Framework 2.0 Help
On our "Getting Started with DAQmx Series," there are great tutorials for many languages, including .NET. Follow the links below and I hope this helps.
Getting Started with NI-DAQmx: Main Page
http://zone.ni.com/devzone/cda/tut/p/id/5434
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
http://zone.ni.com/devzone/cda/tut/p/id/2835
Using NI-DAQmx in Text Based Programming Environments
http://zone.ni.com/devzone/cda/tut/p/id/5409
PBear
NI RF
(2,771 Views)
