usb-daq 6216 analog in
Hai,
I am using a usb-daq 6216 for measuring voltage. I want to test a smps step by step. When i want to sample a channel, it does not give the correct value. When i use the scope, i see that the voltage is at the input of the adc. When i put a voltage on this pin using a lab dc source, it does give the correct value. Why does it not give the value i need when i want to test my smps? i tried diff mode and nrse mode. I do not use rse because i have no steady ground.
Can someone help me out?
Mike
(2,621 Views)
Dear Mike,
Thank you for your post on our website. I want to ask fo some more information about your problem, this will help me to look in the right direction for a solution.
- what are the values you are reading with the daq card and what are the values with your scope (what is the value difference?)
- are you reading the values in the measurement and automation explorer? (please try first)
- please give a overview from the settings you are using (range, sample rate etc)
Martijn
Martijn S
NI Netherlands
(2,565 Views)
Hello Mike,
It is a while ago since my last post. I hope your problems are solved. If not, please don't hesitate to contact me. You will find my phone number below this post.
Martijn Smeulers
National Instruments Netherlands
+31348-433466
Martijn S
NI Netherlands
(2,531 Views)
