usb interfacing in labview
hello dennis ...please have alook of my problem which i posted.
thanks.
robin.
Message 11 of 16
(1,392 Views)
here are single write n read code.....
Message 12 of 16
(1,389 Views)
I'm not sure what anyone can do without having access to your hardware and knowing exactly how you've implemented the USB interface. One thing that is pretty obvious about the gpx_init VI is that you have no dataflow. If it matters what order you perform these operations, add error in/out connections to your subVI (which you did not post) and wire them up. Otherwise you will have these operations called in random order.
Message 13 of 16
(1,354 Views)
Thanks for ur help dennis ..i got the solution....
regards.
robin
Message 14 of 16
(1,348 Views)
hi dennis ..my time to digital conveter program in labview working fine in burst mode (timer mode) ..reading the data from endpoint 2 but when i am configuring it to single shot mode it's not reading anydata ...can you tell wts the reason ?and wht i have to try .with configuration.if you need will send you my programe.plz let me know.
kind regards.
robin.
Message 15 of 16
(1,303 Views)
my usb raw is showing timeout error problem when i am running that in single short mode confogaration but same usb is working properly for timer mode.does anybody knows how to solve that problem?
kind regards
robin.
Message 16 of 16
(1,258 Views)
