usb port reading example
          Can anyone plz attach a  simple working example for READING DATA from a USB port.
Thanks as kudos only:)
(5,686 Views)
Use the LabVIEW Example Finder and search for USB.
You should find: USB RAW - Bulk.vi, USB RAW - Control.vi and USB RAW - Interrupt.vi
Christian
(5,671 Views)
What device are you trying to read data from?
For instance, if it is a USB-to-Serial adapter, you can use native VISA Serial VI's to do the trick.
(5,664 Views)
I found those examples.But it won't seems to be simple.Iam a beginner trying to read from the USB port for the first tine.Can you suggest some simple examples.
ThanxSmiley Happy
(5,648 Views)
USB is not simple. You need to provide details on the actual device you are connecting to.
Do some research here. There have been an excellent set of ' nuggets' written by Intaris. Read them.
(5,645 Views)
nuggets' written by Intaris is very informative thanxSmiley Happy
(5,634 Views)
