usb6008 issues on on runtime
runtime engine 2015, and mxq 2015 was installed on a XP computer. I check the USB 6008 with NI Max test penel on the XP computer, every thing work. A working vi with usb6008   was built.  *.exe  files was generated on a Window 10 computer. the exe file start on the XP computer but the usb6008 does  not produce any data. no error is shown. What Do I miss.
Please help
(3,453 Views)
do you install related drivers ?
(3,427 Views)
Do not post your exe! Post your VI. If we can see your VI, we can get some idea...
(3,407 Views)
Please help
It is pointless to attach your executable.
You are probably missing the DAQmx runtime engine on the new PC. To do a new installation on a PC you should build an installer, not just an executable. The installaer will automatically select and include all the necessary run-time engines required by your application. I usually also include MAX as is it usefull to perform many checks.
Ben64
(3,404 Views)
