use Nonlinear Curve Fit LM for Possion type fitting
Hi, guys,
I am using "Nonlinear Curve Fit LM" for a Poisson type distribution.
The Possion equation is f(x)=a^x*exp(-a)/ x!
Where x! is factorial of x.
How to write this equation to F(x,a) input?
Thanks for help!
Raymond
(4,448 Views)
This will not work, because the factorial function is only defined for non-negative integers of x.
Levenberg-Marquardt fittiing requires that f(x) is a Continuous_function over the useful range of values.
What is the range of X? If X is typically very large, you could maybe substitute Stirling's approximation for the factorial.
(4,443 Views)
Actually, Stirling's approximation is pretty good for all positive inputs.
Here's a quick implementation of your function using the VI model (See insert)
Works pretty well. What is your LabVIEW version?
Message Edited by altenbach on 05-12-2008 05:15 PM
(4,437 Views)
A nice posting, thanks a lot!
I almost get there, but I still have problem to link this subvi to “Nonlinear Curve Fit LM” , I’m not familiar with reference node at all, Could you throw me a little further hint? I am using Labiew 8.5 and the X set range is about 200~300.
(4,417 Views)
Well, then it won't work. The factorial part will overflow the DBL range at about half that.
If your x range is 200-300, your "a" is also in that range. For large "a", you should use a Gaussian centered at "a" and with a variance of "a". See http://en.wikipedia.org/wiki/Poisson_distribution for details (Secton: related distributions).
Here is the version for the Stirling's approximation. See if you can modify it for the gaussian approximation. 🙂
(4,404 Views)
Yeh, Gaussian works well, just want to try something else, I might need to sparse my X array set, use your subvi and then draw the fitted line.
Thanks agian.
(4,380 Views)
