use of analog and digital channel synchronously in DAQ 6361
sorry for convenience.actually I have set trigger for both,I might have not  saved it properly.If trigger is applied to both daqMAx then are they synched?
are you talking about find examples in help section of labview?
can you share the link or vi for that?
Message 11 of 13
(925 Views)
Hi poojap,
It might be synced…
Do you get any errors on the error output of the DAQAssistents when trying to use the very same trigger input in two different DAQmx tasks?
Yes!
Message 12 of 13
(922 Views)
I did not find any error.program works fine the only issue is they are not synchronised.
Message 13 of 13
(919 Views)
