user defined run time window size
Hi everyone,
I learnt that you could draw a box around the controls or indicators on the front panel, so that run time window size will be the same as the box as shown below. However, I forgot how to draw that box. Could anyone remind me please? Thank you very much.
(1,140 Views)
ah, found the solution, just tick this box. I cannot believe that I found the solution immidiately after I post this question. I spent long time to look around for solution.
(1,127 Views)
