user events from labview build dll
Reference to pattern
Previous discussion
I had this pattern in place in a LV 7.1 application using a LabVIEW build DLL, but when migrating to LV 8.5 I found that User Events created in one application instance can not be fired by another application instance. It seems that since LV 8.x a LabVIEW build DLL are a different application instance. The generate user event function generates an error inside the DLL stating that it is not working because it is a reference from another application instance.
Is the behaviour of a LV build DLL different than a C build DLL? Is the C build DLL part of the same application instance as the LV executable?
Is there a way the get the LV build DLL to be a part of the same application instance as the LV build executable or development environment?
André (CLA, CLED)
(3,051 Views)
Hey,
I think the problem you see is that the DLL is build in LV7.1, so it needs LV7.1 runtime engine, which is another application instance than the LV8.5 runtime engine.
Christian
(3,037 Views)
Forgot to tell that I rebuild the DLL in LV 8.5, before making that conclusion.
Message Edited by andre.buurman@carya on 09-04-2008 01:12 PM
André (CLA, CLED)
(3,026 Views)
Is there nobody at NI that can elaborate on this subject?
André (CLA, CLED)
(2,980 Views)
Hello Andre,
My apologies for the big delay in responding to your problem. I couldn't find any information about changes in handling the DLL under 7.1 and 8.x, as far as I can tell there shouldn't be a difference. Because of that I forwarded your question to some colleagues. I hope to inform you as soon as possible.
Have a great weekend,
Martijn S
NI Netherlands
(2,849 Views)
Hello Andre,
Is it possible for you to upload the 7.1 and the 8.5 dll? Also the part of your VI where things are going wron would be great. Please let me know how we can reproduce this error.
Martijn S
NI Netherlands
(2,819 Views)
Ik heb op dit moment geen tijd om de voorbeelden te maken.
Ik kom er zeker op terug wanneer ik weer wat meer tijd heb.
Alvast bedankt voor je inspanningen zover.
André (CLA, CLED)
(2,815 Views)
