user interface from picture
Well, that was just an example. You can easily modify it to read PNG and BMP as well. If you want OpenG has a VI that reads a file directly into a picture.
As for the resizing, you can use the "classic" picture control, make it transparent and use it to cover the entire FP. Then, keep the "size" or your FP in your text file and ignore clicks outside that area.
___________________
Try to take over the world!
Message 11 of 12
(678 Views)
Even though you have got it work, I hope you will, still, find this solution helpful in your coding challenge!
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 12 of 12
(673 Views)
