user interface test screen
Is there any example of user interface screen that i could get idea from. I'm more interested in designing a test screen that contains sequential tests.
Message 1 of 10
(5,081 Views)
sequential tests.
Can you elaborate a little bit?
Message 2 of 10
(5,058 Views)
I would like to design a user test screen that looks similar to Test Stand test screen where it will execute all test steps in sequence (test 1, test 2, test 3, etc...). Each test step would show the test name, pass/fail spec. raw data, and test result on each row.
Message 3 of 10
(5,044 Views)
Hi dphan128,
So, would a simple 2D array work for you?
Jeff | LabVIEW Software Engineer
Message 4 of 10
(5,038 Views)
Hi Jeff,
Anything that works is fine for me! Could you explain how to implement in LabVIEW code since this is new to me.
dphan128
Message 5 of 10
(5,027 Views)
What do you want on the UI screen?
Just an array? Test results? Graphs?
You would need to elaborate a little bit.
Cory K
Message 6 of 10
(5,024 Views)
I tried something for you
Message 7 of 10
(5,000 Views)
Yeah, we really need to know what you want to see in terms of user interface. LEDs for pass/fail? Just a table of data? etc.
Message 8 of 10
(4,989 Views)
Bsiscally, I want something in table format that looks like this:
Test name
SpecsResult
Message 9 of 10
(4,976 Views)
It sounds like a 2D array of strings might be appropriate for you, maybe with separate labels for the titles for simplicity.
Message 10 of 10
(4,960 Views)
