user interface
I have a problem i have a data file with 4 string elements per line and a large number of lines, about 100.
what i want to do is create a user interface that displays a check box and next to it element #4
for each line in my data file, a scroll box would work well if its possible.
i then will parse all the items that the user selected and use the first 3 feilds to generate the appropriate output.
any suggestions how i can do this??
(3,378 Views)
You could simply use a listbox set to select zero or more items. Then you can select mutiple items using the mouse and the ctrl key.
Attached is a quick draft (LV7).
Aternatively, you could e.g. add a checkbox symbol whenver a line is double-clicked in the listbox, etc.
(3,378 Views)
the example you provided has given me a new idea, actually i'm borrowing yours,
thanks for your help.
(3,372 Views)
now if i could figure out how to not press the ctrl key to select multiple items this vi will be perfect
(3,366 Views)
