username and password authentication
Use either .csv or .ini file to store the usernames and passwords.
you can easily read these files.
If you want to make your authentication very highly secured. Then, you have to go for some other file format which is not readable by humans.
Manikandan.
Message 11 of 16
(2,188 Views)
That is probably the single worst suggestion that could be made on storing passwords and user names.  Please don't do this, unless it is a homework assignment.  Any real project needs to avoid storing passwords in plain text.
Message 12 of 16
(2,182 Views)
Hi, i know that is very worst suggestion for storing password and username in text based file.
He just want to check that in LabVIEW it seems. That's why i asked him to do with text based file.
Message 13 of 16
(2,175 Views)
hello there, I am very new to labview. can anyone help me with this small program to check the username and password
thank you
Message 14 of 16
(2,189 Views)
I think your problem is not the function itself. I think it's LabVIEW knowledge.
According to your information in your VI, try to use search 1D array. it might direct you to something.
I may also suggest you to find some training or book on LabVIEW beginner. so you will know where to start.
Benoit
Message 15 of 16
(2,171 Views)
As Suggested you should take some tutorials.
To Suggest for your Requirement you should use 2D Array (1 Column for UserName and Another For Password)/ Array Cluster (Cluster of Two Elements) for Storing User Details.
In case of reading from the file, format the Read Value in above suggested format.
Then User Search 1D Array to Find The User Name, If Search 1D Array Gives Any Value other than -1, use the Index to get the Password From the Password Column.
Then Compare the Password entered by the user and the Passed you extracted based on User Name from 2D Array.
Same Applies for Cluster data as well.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 16 of 16
(2,152 Views)
