using 2 ni usb 9215 devices to sample 8 channels Simultaneous
I Need to sample 8 channels Simultaneous using usb devices.
If i use 2 9215 ( 4 channels ) devices in a 9172 chassis i will get acctually 8 channels Simultaneous ?
Does the 2 devices use the same clock?
Is it realy Simultaneous ?
(3,250 Views)
I believe they have to be installed in slot #5 and #6.
See the manual.
Ben
(3,244 Views)
Hi Ben,
Thanks for your help,
Can you be more specific?
It's not so clear in the manual.
I just want to be sure it is possible to have 8 samples Simultaneous before i buy the devices.
(3,240 Views)
If you want to be sure, then don't trust me! Smiley Surprised
I suggest you call NI directly and when talking to the inside sales rep, ask them to let you talk to support so they can send you an e-mail stating if the operations you need are supported.
Ben
(3,228 Views)
Hi barak,
You can definitely use 2 NI 9215 modules in a cDAQ-9172 chassis to simultaneously sample 8 channels.  The modules can be in any slots (slots 5 and 6 are just for certain triggering applications on digital modules).  You'll need to use them in the same NI-DAQmx task, and they will share a sample clock and sample data at the same time, give or take a few nanoseconds and the specs of the modules themselves.
Calling NI to discuss your exact app is a great idea too.  They'll be able to answer these and any other questions you have.
Kyle
(3,223 Views)
