using CIN's
I have an old motor controller card, in which there are no labview drivers.
I have a C code so that the card may be talked to. I know the commands to
move the card, and the C code, when compiled into a dll will communicate.
I just need to know a few things. First, how do I integrate the dll into
labview, via CIN? Second, how do I send the commands to the CIN, or, more
particularly, to the dll via labview?
Any help on this would be most appreciated. Thanks
JMH
(3,320 Views)
NI website have examples on this.
"JMH" wrote in message news:39858b4d@newsgroups.ni.com...
> Hi,
drivers.
> JMH
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Di
fferent Servers! =-----
(3,320 Views)
You can call dll from VIs directly.
For this use the Functions Palette->Advanced->Call Library Function
node. For configure of parameters passing, right click on this node
after you place it in VI Diagram and then select Configure option.
Kostya.
In article <39858b4d@newsgroups.ni.com>,
"JMH" wrote:
> Hi,
drivers.
commands to
communicate.
into
more
> Any help on this w
> JMH
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,320 Views)
