using DAQ MAX property node How to get custom scaling values from Measurement and automation explorerusing property node How to get custom scaling values from Measurement and automation explorer
Hai friend,
                Actually i have configured a Analog input as a virtual channel . In Measurement and automation explorer i have configured a channel in custom scaling i have create a new in which i have entered the scaling parameters slope and Y - intercept and i saved the channel. Now  i need those values for calculations in VI. so  how to take those  values  from  Measurement and automation explorer.....
(2,787 Views)
In LV under the Daqmx pallete/ Advanced functions/  scale setup, their is a property node that will let you get the parameters of the scale. I have never used it before but it should do what you described.
Joe.
"NOTHING IS EVER EASY"
(2,779 Views)
