using FTP in Novell Network
Hi all,
does someone know, if I can use the FTP-functions of the labview
internet toolkid to send files in a LAN with Novell Servers?
Thanks, Niko
(2,643 Views)
As long as the network is using TCP/IP protocol and there's an FTP server running, I don't think you'll have any problems. If you want to test it before buying the toolkit, every Windows OS comes with an FTP client program. It's available from the command line window.
(2,643 Views)
Dennis gave a great answer. There is also a Knowledge Base on www.ni.com named "How Do I Transfer Files With FTP?"
Here is the link : http://digital.ni.com/public.nsf/websearch/EF2C5AE37FE3672186256C3D005489A0?OpenDocument
It gives a few helpful tips about connecting to an FTP server. Good luck with everything!
BB_Phil
(2,643 Views)
