using LabVIEW in CNC Milling tool holder
Hello everyone,
I am a beginner in LabVIEW but I would like to know how to select/compare suitable drivers and modules for a mechatronic tool holder that is used in a CNC machine!
Also, can wireless technology be applied in this case because the machining environment doesnt not facilitate wired connections
(2,853 Views)
This seems more like a hardware instead of a software question.
I assume that all your hardware choices offer LabVIEW drivers. Are you asking about driver quality?
Typically, you can think of "wireless" as plain Ethernet. It does not really matter how the connection is physically done. LabVIEW supports plain tcp, udp as well as higher level things such as web services, remote panels, and much more.
(2,816 Views)
