using Labview to test Serial Interface Valve Manifolds
I am fairly new to Labview and have been given a task to assemble a test stand that will test various Serial Interface protocol Valve Manifolds (Pneumatic).   To my knowledge I see two directions for this test.   One would be to purchase RS Logic Rack and all of the protocal Interfaces or use Labview.   Since I am more familiar with Labview, this would be ideal.   I now need to know where to start and what hardware I will need to accomplish this.   The protocols we need to test are:  ControlNet, Device Net, Remote I/O, Profibus, EtherNet/IP, Asi, Compobus-S, CC-Link and if possible MelsecNet/Mini-S3, CanOpen and Sysbus.   The test stand will only need to test one valve manifold at a time so the user would simply select the p/n of the manifold and the program would then select which protocal is required (this is the easy part).   Then test just the I/O.   So, the question is can Labview be used?   What hardware and Software will be required?  We have Labview 8.2.
I have attached our SI brochure for reference.
Also, I am sorry in advance if this is the wrong board.
I would appreciate any feedback.
thanks,
Message 1 of 1
(2,920 Views)
