using a DLL that passes back a pointer location to its own internal memory
I have a DLL which I would like to use in LabView
unfortunately, the DLL uses an internal memory buffer, and only passes back a pointer to the buffer.
I found some help on your web site which gets around this by using an undocumented LabView function
with an example: lvPointer.... Library name: LabView, Function Name MoveBlock
void MoveBlock(unsigned long src,long *dst, long size)
I understand that this function internally creates the memory and moves the data to the new location, returing the array.
I now have a huge memory leak, unless I can deallocate this memory (since I am getting data from the DLL into a new array every time, 50 times a second, 16k each time), how can I do this?
(2,643 Views)
hi there
i'm just guessing: who frees the initial memory (unsigned long src)?  have you tried to call free(unsigned long src) after MoveBlock?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,638 Views)
Appologies, I was being stupid.
The BlockMove is passed a buffer in the first place, so I can just reuse it, while the DLL cleans itself up.
Thank for the help
Best regards
(2,634 Views)
