using a .dll to control a mcs device
Thanks again for your help tyk 007
i contacted multichannel systems today and they knew what caused the problem. so i can now use the tcx controller and have no more issues.
dears michael
Message 11 of 13
(719 Views)
Glad you have solved your problem. If you get a chance feel free to post the solution here in case someone else encounters the same problem.
Message 12 of 13
(712 Views)
Accepted by topic author octaris
The support of Multichannel systems provided me an example how to do it in c# programming and its the same way doable with the invoker nodes in labview:
 CMcsUsbListNet usbDeviceList = new CMcsUsbListNet();
            usbDeviceList.Initialize(DeviceEnumNet.MCS_TCX_DEVICE);
            CMcsUsbListEntryNet entry = usbDeviceList.GetUsbListEntry(0);
using the .net dll provided from the mcs webside all those functions are imported to labview.
and using the commands above the connection to the tc01 thermocontroller works.
Message 13 of 13
(708 Views)
