using a measurement computing PCI-Das1001 board
Do you have any examples for using this board? Thanks
(2,917 Views)
Why would NI have examples of code for a DAQ board from another vendor? Have you asked Measurement Computing?
(2,896 Views)
Hi ppont,
There is a member that has been posting code on the forums, and it appears that they are using the same PCI-DAS1001.
Here are the links:
1) My sequence with a subvi in it stops in the first frame that contains the subvi.
2) Step through array
I hope this helps!
(2,878 Views)
We'll-- in this case (MCC) I would expect some information sharing would occur.  Even though the development teams remain seperate, customer support should be communicating at an operator-operator level and have an established cross platform hand-off policy to maximize the value of the corporate relationship.  (NI owns MCC)
(2,864 Views)
