using activex to write to excel
is there any other way to write to excel using activex besides using method node worksheeet: range where the location of the cells are required.  can i just create a range refnum to feed into the property node range: value, then write to it?
(3,115 Views)
I'm not sure that I understand the nature of your question. You are inserting data into a spreadsheet, which is composed entirely of cells, so you have to tell Excel into which cells you want to insert your data. If you don't care which cells they go into, why not just specify (0,0)? Is there any particular reason why you don't want to specify a range?
Kind Regards,
E. Sulzer
(3,092 Views)
